How to start Node-red automatically on boot using init.d
Sidnei Marcondes 08 May 2019 min. read
1,288 views 1 comments
This procedure describes how to start Node-red automatically when the PLCnext starts. It is a alternative to pm2 that apparently it is not working with the node from PLCnext Store.
The idea is to include a script to run in init.d directory. The script bellow was adapted from the script found in the node-red page.
1) Log in to the PLC as root:
Using username "admin".
admin@192.168.1.2's password:
Last login: Wed May 8 15:33:03 2019 from 192.168.1.120
admin@axcf2152:~$ su root
Password:
root@axcf2152:/opt/plcnext/#
2) Change to init.d folder and open a new file with the name “start_nodered”
root@axcf2152:/opt/plcnext/# cd /etc/init.d
root@axcf2152:/etc/init.d# sudo nano start_nodered
 3) Copy the script bellow to this file. This script can be found in the follow link Link to start_nodered script
#! /bin/sh
### BEGIN INIT INFO
# Provides:          node-red
# Required-Start:    $local_fs $remote_fs $network
# Required-Stop:     $local_fs $remote_fs $network
# Default-Start:     2 3 4 5
# Default-Stop:      0 6
# Short-Description: Start or stop the node-red server
### END INIT INFO
# Script to start node-red with PLCnext from Phoenix Contact using init.d
# Execute these commands:
# sudo chmod 755 start_nodered
# sudo update-rc.d start_nodered defaults 99
USER=root
USER_DIR='/opt/plcnext/.node-red'
PATH=/usr/bin:/usr/sbin:/opt/plcnext/apps/60002172000051/opt/node-v10.15.3-linux-armv7l/bin
NAME=node-red
DAEMON=/opt/plcnext/appshome/data/60002172000051/bin/node-red
OPTIONS="--max-old-space-size=128"
if [ -n "$USER_DIR" ];  then
    OPTIONS="$OPTIONS --userDir=$USER_DIR"
fi
LOG='/var/log/node-red.log'
PIDFILE=/var/run/node-red.pid
. /etc/init.d/functions
start_daemon () {
        start-stop-daemon --start --background
        --chuid $USER --name $NAME
                $START_STOP_OPTIONS --make-pidfile --pidfile $PIDFILE
        --startas /bin/sh -- -c "$DAEMON $OPTIONS >> $LOG 2>&1"
    echo "Logging to "$LOG
case "$1" in
        start)
             echo "Starting daemon" "$NAME"
             start_daemon
        stop)
             echo "Stopping daemon" "$NAME"
             start-stop-daemon --stop
             --user $USER
             --name $NAME --pidfile $PIDFILE --retry 30
             --oknodo
        restart)
         $0 stop
         sleep 5
         $0 start
    status)
             status "$DAEMON" "$NAME"
             exit $?
             echo "Usage: $0 {start|stop|restart}"
             exit 1
esac
exit 0
4) Execute the two commands bellow:
root@axcf2152:/etc/init.d# sudo chmod 755 start_nodered
root@axcf2152:/etc/init.d# sudo update-rc.d start_nodered defaults 99
5) Restart the PLC and check if Node-RED has started.
  • It is important to keep the file name with “start” or any other word that starts with letter with or after “s” to ensure that the Node-red will start after all others process.
charkrit.orion 18.11.2022
I've used this method with good success. However recently I encountered an error. The command `update-rc.d scriptName defaults 99` returns `Can't locate File/Glob.pm in @INC (you may need to install the File::Glob module) (@INC contains: /usr/lib/perl5/site_perl/5.30.1/arm-linux /usr/lib/perl5/site_perl/5.30.1 /usr/lib/perl5/vendor_perl/5.30.1/arm-linux /usr/lib/perl5/vendor_perl/5.30.1 /usr/lib/perl5/5.30.1/arm-linux /usr/lib/perl5/5.30.1 .) at /usr/sbin/update-rc.d line 65. BEGIN failed--compilation aborted at /usr/sbin/update-rc.d line 65.`
