Installing PIP on PLCnext Control
stijn 03 November 2021 min. read
6,999 views 3 comments
What if you do not need a newer version of Python than the one that comes preinstalled on the controller, but you do want pip installed? There is a simple way to do so!
You can download the installation script via the curl command:
curl https://bootstrap.pypa.io/get-pip.py -o get-pip.py
The above command downloads an installation file to the current directory which you can execute with the following command:
python3 get-pip.py
This will install pip on your controller together with wheel and setuptools.
If you wish not to install these, you can install pip with the following command:
python3 get-pip.py --no-wheel --no-setuptools
ayoub 04.03.2022
Hello I have an issue with permission. When I did run "python3 get-pip.py" I got the following error. epiroc@axcf2152:~$ python3 get-pip.py Defaulting to user installation because normal site-packages is not writeable Collecting pip Using cached pip-22.0.3-py3-none-any.whl (2.1 MB) Collecting setuptools Using cached setuptools-60.9.3-py3-none-any.whl (1.1 MB) Collecting wheel Using cached wheel-0.37.1-py2.py3-none-any.whl (35 kB) Installing collected packages: wheel, setuptools, pip ERROR: Could not install packages due to an OSError: [Errno 13] Permission denied: '/opt/plcnext/.local/lib' Check the permissions. When I used "sudo python3 get-pip.py" It seems that I cannot reach to all folders. Although, my user is set as admin. epiroc@axcf2152:~$ sudo python3 get-pip.py Password: Sorry, user epiroc is not allowed to execute '/usr/bin/python3 get-pip.py' as root on axcf2152. I login with admin user and used the password that was typed on the PLC I had the same issue. I would be appreciated it if you could help.
Martin PLCnext Team 21.04.2022
It worked for me, as admin, from the /opt/plcnext directory. The output from the commands is shown below. ================================= admin@axcf2152:/opt/plcnext$ curl https://bootstrap.pypa.io/get-pip.py -o get-pip.py % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 100 2596k 100 2596k 0 0 762k 0 0:00:03 0:00:03 --:--:-- 763k admin@axcf2152:/opt/plcnext$ python3 get-pip.py Defaulting to user installation because normal site-packages is not writeable Collecting pip Downloading pip-22.0.4-py3-none-any.whl (2.1 MB) ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 2.1/2.1 MB 755.7 kB/s eta 0:00:00 Collecting wheel Downloading wheel-0.37.1-py2.py3-none-any.whl (35 kB) Installing collected packages: wheel, pip WARNING: The script wheel is installed in '/opt/plcnext/.local/bin' which is not on PATH. Consider adding this directory to PATH or, if you prefer to suppress this warning, use --no-warn-script-location. WARNING: The scripts pip, pip3 and pip3.8 are installed in '/opt/plcnext/.local/bin' which is not on PATH. Consider adding this directory to PATH or, if you prefer to suppress this warning, use --no-warn-script-location. Successfully installed pip-22.0.4 wheel-0.37.1
didierkere 27.06.2023
Hello I encountered a different issue. i try running the curl command but i get 0curl (6) could not resolve host https. i tried as an admin and as a root user Thanks in advance for any future help
mmancilla 16.08.2024
When I execute the command it gives me the following error: "curl: (60) SSL certificate problem: certificate is not yet valid"
Martin PLCnext Team 19.08.2024
Certificate errors are often caused by the time being incorrect on the device. What is the current time on the PLCnext Control device?
