Retain Counter for Operating Hours for PLCnext Engineer
harald.baerdges@phoenixcontact.de 22 March 2021 min. read
578 views 1 comments
Hello, Friends of the PLCnext Technology.
A Customer asked me for a Retain Measurement of Operating Hours in the PLCnext Engineer.
Unfortunately there wasn’t anything available.
So i created my own Function Block. Here is all the information you need to use it yourself.
It automatically creates a second impuls by using two TON FBs if the Measurement-Input (Verbraucher) is high.
Using this method it creates Seconds, Minutes, Hours and up to 32.000 Days.
It can be reseted manually or by a Cold Start. Warm Start or switching the Controller On/Off
will keep the Values. Be sure to set the Measurement Variables to Retain!
Variables:
Verbraucher – Bool – Input
xReset – Bool – Input
iCS – Integer – Output – Retain
iCM – Integer – Output – Retain
iCH – Integer – Output – Retain
iCD – Integer – Output – Retain
R_TRIG_UP – R_Trig, R_TRIG_RESET – R_Trig, TON1 – TON, TON2 – TON
Code:
TON1(IN := TON2.Q, PT := t#500ms, Q => , ET =>);
TON2(IN := (Verbraucher and not TON1.Q), PT := t#500ms, Q => , ET => );
R_TRIG_UP(CLK := TON2.Q);
R_TRIG_RESET(CLK := xReset);
If R_TRIG_UP.Q AND (iCS < 60) then iCS := iCS + INT#1;
    Elsif R_TRIG_Reset.Q OR iCS = 60 then iCS := INT#0;
    END_IF;
IF ICS = 60 then ICM := ICM + INT#1;
    Elsif R_TRIG_Reset.Q OR iCM = 60 then iCM := INT#0;
    END_IF;
IF ICM = 60 then ICH := ICH + INT#1;
    Elsif R_TRIG_Reset.Q OR iCH = 24 then iCH := INT#0;
    END_IF;
IF ICH = 24 then ICD := ICD + INT#1;
    Elsif R_TRIG_Reset.Q OR iCD = 32000 then iCD := INT#0;
    END_IF;
o.rapiman01@gmail.com 21.12.2024
I timed it but it has a very large lag, and the longer the time goes the worse it is, I don't understand why plcnext doesn't have retentive timers
