Userdefined Array in Native Function Block and some questions about it
liqunzhao 17 November 2023 min. read
1,827 views 1 comments
Demo description
  • The following example uses the Native Function Block to create a user-defined Array interface with PLCncli toolchain
  • The Array consists of 21 elements, each of which is a structure. The structure contains two IecString80, and an enumeration, as shown in the following diagram.
Requirements
  • Make sure that the ToolChain version is 23.0 or higher. This example uses the 23.6 ToolChain for demonstration purposes.
  • Familiar with the basic process of establishing a Native Function Block.
  • Visual Studio 2019 or 2022 with ToolChain add-in plugins
$ plcncli  --version
plcncli 23.6.0.1450 (23.6.0.1450)
STEP1
  • Create a new project using Visual Studio, select "Shared Native Function Block" project type, and name the project "ArrayTest."
  • Then, within the ArrayTest project in Visual Studio, create a new Native Function Block named "ArrayCplus."
STEP2
  • Copy those code to ArrayCplus.cs
  • Because there are some display issues when directly including the source code here, such as & and >, I provided a link instead.
  • for example, the & will be encode as & in this html.....
ArrayCplus.cs
STEP3
Open the terminal in the ArrayTestCpp folder and enter the following.
$ plcncli generate code
After generating the code, locate the ArrayTest-cli32.h and ArrayTest-cli64.h files in the src directory, and find the places where #error is indicated.
We need to remove the comments and improve the code. Click to navigate to InArrayFB-cli.cpp and modify the implementation.
IntArrayFB-cli.cpp
STEP4
In ArrayCplus.cpp, enter the following code. Contents containing strings must be initialized in the process rather than in the Init region; initializing them in the Init region will not work, resulting in the inability to write values to sName and sAttribute through Engineer.
ArrayCplus-cli.cpp
STEP5
$ plcncli build all
$ plcncli deploy
STEP6
Open the PLCnext Engineer and load the ArrayTest.pcwlx add an variable to the ArrayTest named arr
Now it can work
Questions
  • Although this method works in practice, why is it necessary to initialize content containing IecString or User-defined String in the void PInvoke ArrayTest::ArrayCplus::Process() instead of in the void PInvoke ArrayTest::ArrayCplus::Init()? it doesn't work if i put the code in the void PInvoke ArrayTest::ArrayCplus::Init().
  • It's clear that there is no corresponding tutorial on userdefine arrays for Native Function Blocks on GitHub. Can somebody supplement and improve it? (the way that Csharp Userdefine array is not work in the native function block)
  • One last point that also confuses me is why, regardless of whether it's IecString, User-defined String, or IecStringEx*, if they contain strings, they must be in the form of 【InOut】in CSharp code when used as a Native Function Block?
liqunzhao 30.11.2023
After communicating with Martin Boers, the first question has been answered. By building an Init() function in Structure and Array in CSharp, it can be implemented in C++ to achieve initialization effects. As for the third question, after applying the method from the first question, interfaces containing String can now be specified as [Input] instead of [InOut], and I have updated the corresponding code repository. Nice ~
