VLAN setup in PLCnext Technology
Marcel PLCnext Team 16 September 2022 min. read
1,915 views 1 comments
Currently on a PLCnext Control it is not possible to configure VLAN as easy as a static IP-address. But with some Linux knowledge, access to the terminal and the root account it is possible.
Let's start directly into the terminal as root and use the following three commands to setup a VLAN for the current session.
/sbin/ip link add link <DEVICE> name <NAME> type vlan id <VLAN_ID>
/sbin/ip addr add <VLAN_IP/MASK> dev <NAME>
/sbin/ip link set dev <NAME> up
First command ip link is adding a new network device configuration.
DEVICE specifies the physical device to act operate on.
NAME specifies the name of the new virtual device.
TYPE specifies the type of the new device. In our case the device is of type vlan.
VLAN_ID specifies the VLAN Identifier to use. Note that numbers with a leading " 0 " or " 0x " are interpreted as octal or hexadecimal, respectively.
The second command is adding the address and mask for our new device and the last one activates the vlan via setting the status to up or can also be used to deactivate it via down.
In the following example we are adding a vlan to our eth0 physical interface with the name eth0.99 and the id 99. Best practice here is to use the interface name and adding the id, to be able to identify your vlan faster.
/sbin/ip link add link eth0 name eth0.99 type vlan id 99
/sbin/ip addr add 192.168.1.10/24 dev eth0.99
/sbin/ip link set dev eth0.99 up
To make it persistent over reboots, just create an init.d script.
The script, in our example called vlan.sh, could be a very simple like the following one:
#!/bin/sh
start() {
stop() {
        /sbin/ip link set dev eth0.99 down
        /sbin/ip link delete eth0.99
case "$1" in
  start)
    start
  stop)
    stop
  restart)
    stop &&
    start
    echo "Usage: $0 {start|stop|restart}"
esac
It must be located at /etc/init.d/.
To register the script for the start-up, use the following command:
/usr/sbin/update-rc.d vlan.sh defaults 81
In the example a priority of 81 is used, to make sure, the network is up and running and the applications dependent on our vlan are probably not.
After a reboot you can use the following command to get some information about your vlan if it is up and running.
/sbin/ip -d link show eth0.99
And to stop the script launching on start-up use this command:
/usr/sbin/update-rc.d -f vlan.sh remove
javirivela 10.01.2024
Hello, I tried to follow the tutorial and everything went ok, I launched the ifconfig command from AXC F 2152 and the vlan is created with its name and id correctly. The problem is that then I tried to ping the ip of the VLAN but the device does not respond. Any idea what it could be?
PLCnext Marcel 10.01.2024
Hello Javirivella, is your device, which is executing the ping also in the same vlan? In Windows e.g. its a bit complicated and depends on the network card and its driver capabilities. In most Linux systems you could use the same method as above via "ip".
