OPC UA device information
The Device Integration (DI) namespace
In compliance with the OPC UA for Devices OPC UA Companion Specification, the eUA server provides the following nodes:
Node Meaning
DeviceManual
Path or URL to the user manual.
DeviceRevision
General revision status of the device.
Note: The eUA server does not support this node.
Default value: Empty string
HardwareRevision
Hardware revision status, e.g., 02.
Manufacturer
Device manufacturer, e.g., en, Phoenix Contact
ManufacturerUri
URI of  the manufacturer, http://phoenixcontact.com
Model
Name of the model, e.g., en, AXC F 2152
ProductCode
order number of the controller
RevisionCounter
Revision status of the static device data, e.g., 2
SerialNumber
Device serial number, e.g., 13254768
SoftwareRevision
Software version number, e.g., 2022.0 LTS (22.0.0.123)
Firmware update
Available from 2022.0 LTS
The following facets are supported:
