Configuration of the OPC UA® server with PLCnext Engineer
You can configure the OPC UA® server with the software PLCnext Engineer. For more information about the configuration options refer to the section OPC UA Server in the Online Help of PLCnext Engineer. You can find the PLCnext Engineer Online Help within the software at the HelpView Help menu.
Tip: Starting with release 2022.0 LTS, the PLCnext Engineer embedded help is also online available.
