REST data interface - Collections and dictionaries
Available from firmware 2019.9
This topic shows how to retrieve the dictionaries for the REST data interface, and gives exemplary postman collections for the commands that are described thoroughly in the respective topics.
Note: Phoenix Contact reserves the right to make changes and additions in further versions that might lead to incompatibilities. Therefore it is highly recommended to call this REST data interface out of your application explicitly with the version used during development, not with the latest key.
Postman collections
To download a collection of the requests in this REST data interface, just click the links and unpack:
Note: Consider the API version addressed therein.
Dictionaries
To retrieve a dictionary, you can use the following calls:
Retrieving the data dictionary
GET https://%PlcAddress%/ehmi/data.dictionary.json
where
%PlcAddress% is the address of the PLC
returns a JSON with all available variables and their type information.
Hide the exampleClick to show an example response
Example response:
    "$schema":"http:\/\/json-schema.org\/draft-0\/schema#",
    "title":"DataDictionary",
    "HmiVariables2":
        "Arp.Plc.Eclr/ESM_DATA.ESM_INFOS[1].TICK_COUNT":
            "Type": "DINT",
            "InitValue": "0",
            "ReadOnly": true
        "Arp.Plc.Eclr/Test_Global":
            "Type": "BOOL",
            "InitValue": "FALSE"
        "Arp.Plc.Eclr/Test_Global_GroupVar1":
            "Type": "BOOL",
        "Arp.Plc.Eclr/Test_Global_GroupVar2":
            "Type": "BYTE",
            "InitValue": "BYTE#16#0"
        "Arp.Plc.Eclr/Test_Global_GroupVar3":
            "Type": "WORD",
            "InitValue": "WORD#16#0"
        "Arp.Plc.Eclr/Test_Global_GrouptVar4":
            "Type": "DWORD",
            "InitValue": "DWORD#16#0"
        "Arp.Plc.Eclr/TestArray":
            "Type": "arrByte_Stream",
            "InitValue": ""
Retrieving the type dictionary
GET https://%PlcAddress%/ehmi/type.dictionary.json
where
returns a JSON with all used datatypes.
Example response:
  "title":"TypeDictionary",
  "Types":
      "Name": "DINT",
      "RuntimeType": "System.Int32",
      "RuntimeSize": 4,
      "RuntimeAlignment": 4,
      "Kind": "Elementary"
      "Name": "BOOL",
      "RuntimeType": "System.Boolean",
      "RuntimeSize": 1,
      "RuntimeAlignment": 1,
      "Name": "BYTE",
      "RuntimeType": "System.Byte",
      "RuntimeSize": 1,
      "Name": "WORD",
      "RuntimeType": "System.UInt16",
      "RuntimeSize": 2,
      "RuntimeAlignment": 2,
      "Name": "DWORD",
      "RuntimeType": "System.UInt32",
      "RuntimeSize": 4,
      "Name": "arrByte_Stream",
      "RuntimeType": "ProConOS_eCLR.arrByte_Stream",
      "RuntimeSize": 28,
      "Kind": "Array",
      "ElementType": "BYTE",
      "Dimensions":
          "StartIndex": 0,
          "Length": 28
