Features of PLCnext Engineer
In this topic you see the current features and the software version with which they have been implemented. For a sneak peek into our further development and current activities on this Engineering software, please refer to the PLCnext Engineer roadmap.
Latest Update: September 18th, 2024
Note: In this topic, the versions in the table headers are relating to the software version, not the firmware running on the PLCnext Control. Some new PLCnext Engineer features depend on the corresponding firmware release.The release strategy and rhythm for both software and firmware is almost the same; but release 2021.3 is valid only for the PLCnext Engineer software suite. For the firmware, there was no such release.
Supported devices
PLCnext Engineer version 2019.0
LTS
2020.0
LTS
2021.0
LTS
2022.0
LTS
2022.3 2022.6 2022.9 2023.0
LTS
2023.3 2023.6 2023.9 2024.0 LTS 2024.6
AXC F 1152
AXC F 2152
AXC F 3152
RFC 4072S
RFC 4072R
BPC 9102S
EPC 1502
EPC 1522
AXC F XT SPLC 1000
General features
LTS
2020.0
LTS
2021.0
LTS
2022.0
LTS
LTS
Network scan for compatible controls
PLCopen XML (IEC 61131-10) import from PC Worx 6
PLCopen XML (IEC 61131-10) import and export of POU and data types
Device Replacement
(keeps data of existing objects if possible)
Safety Device Replacement
AutomationML - APC (Automation Project Configuration)
Project statistic overview (consumption and limits)
Native support of 64-bit Operation Systems (Windows 7/10)
(32-bit systems are no longer supported)
Download sources with libraries
Translation Management (comments and strings)
NTP time server configuration
Import/export of data lists as .csv file
DataLogger session configuration
Network topology viewer
Release of mixed libraries
Converter for PC Worx 6 projects
Coupling of SVN and Git repositories
Export a package of project binary files
User interface
LTS
2020.0
LTS
2021.0
LTS
2022.0
LTS
LTS
Multiple screens support - Cross-function area
Multiple screens support - HMI dynamic and property editor
System filter
Global cross references
Local cross references
Recycle bin function
Mini Map ("Bird view")
Support of multiple instances
Copy & paste between multiple instances
Chinese language support
IEC 61131-3 editor and features
IEC 61131-3 programming
LTS
2020.0
LTS
2021.0
LTS
2022.0
LTS
LTS
Background compilation and syntax check
Download change
Structured Text (ST)
Function Block Diagram (FBD)
Ladder Diagram (LD)
Network-orientated editor (NOLD)
Extended variable identifier
Initialization of user-defined data types
Initialization of user-defined data instances
Copy POUs from libraries
Overwrite data types from libraries
Overwrite POU types from libraries
Documentation editor @POUs
Create externals from global variables
NOLD editor – expand/collapse networks
NOLD editor - adjustable width
Variable type "Constant"
Editor supports up to 20 worksheets per POU
Navigate to definition from POU instance
EN/ENO parameters (in 2022.0 LTS re-implemented with better functionality)
Refactoring of variables
WSTRING datatype
Arrays assignable to process data items
Import/export of variables list as .csv file
Escape sequences for STRING / WSTRING literals
Object-orientated programming (OOP)
LTS
2020.0
LTS
2021.0
LTS
2022.0
LTS
LTS
Methods for function blocks
User-defined namespaces
Sequential function chart (SFC+) – Add-in
LTS
2020.0
LTS
2021.0
LTS
2022.0
LTS
LTS
Basic functions
Interlocks
Watchdog
Type & Info struct
Compact SFC function block representation
Pre- and post-execution worksheet
Safety IEC 61508 editor
PLCnext Control RFC 4072S is the first PLC to support IEC 61508 safety features.
LTS
2020.0
LTS
2021.0
LTS
2022.0
LTS
LTS
PROFIsafe® compliant
Network granular CRC
Signal path analysis
Safe semantic analysis
Functional Safety - User libraries
Undo/Redo functionality in safety editor
Auto-generate safety variables by connecting to a Safety I/O
Resource statistics view for Safety PLC
Reloadable C functions
Task editor for Safety task
Download of safety and non-safety application
by a single command
Integrated HMI editor
LTS
2020.0
LTS
2021.0
LTS
2022.0
LTS
LTS
LTS
2024.6
Basic forms and elements
Symbols
Symbol in symbol (one level)
Symbol in symbol (multi-level)
Animations
Animated timer
Actions – Execute an event
Actions – Multiple events
Actions – Write value
Search and replace in symbols and dynamics
Import and export HMI Libraries
Import pages from other projects
Access IEC 61131-3 external variables
Access local variables of function blocks
Tags – Primitive data types
Tags – Any Bit (e.g. var. %X1)
Tags – Array
Tags – Struct
Tags – Array of Struct
Tags – Local function block variables
Tags – Assign UDTs to symbol parameters
Tags – Define local tags for symbols
Folder in HMI application tree
eHMI Easy Login - refresh without re-authentication
Object Explorer shows a hierarchic tree view of HMI objects
Actions triggered on page-activated event
Actions triggered by data
Trending chart view
Multi-language applications
Expressions in symbol parameters
Editor for page templates
Drop list symbol
Alarming (configurable alarms)
PROFINET support
Note: GSDML files that comply with profile version 2.2 must also contain the attribute DeviceAccessPointItem/@PNIO_Version with a value ≥"V2.0".
LTS
2020.0
LTS
2021.0
LTS
2022.0
LTS
LTS
Supported GSDML profile 2.2 to 2.34 2.2 to 2.35 2.2 to 2.4 2.2 to 2.42 2.2 to 2.42 2.2 to 2.42 2.2 to 2.42 2.2 to 2.42 2.2 to 2.42 2.2 to 2.42 2.2 to 2.42 2.2 to 2.42 2.2 to 2.42
Scan for PROFINET devices
Global PROFINET interface table
(all interface settings in one table)
MRP configurator
PROFINET redundancy
PROFINET Fast Start-up (FSU)
Create preconfigured device templates
Axioline support
Only with Axioline F series controllers.
LTS
2020.0
LTS
2021.0
LTS
2022.0
LTS
LTS
Support for Axioline local bus
Support for Axioline Smart Elements
Inline support
Only for AXC F x152 controllers with AXC F IL ADAPT extension.
LTS
2020.0
LTS
2021.0
LTS
2022.0
LTS
LTS
Supported of Inline local bus
Ethernet extension support
Only for AXC F 2152 or AXC F 3152 controllers with AXC F XT ETH 1TX extension.
LTS
2020.0
LTS
2021.0
LTS
2022.0
LTS
LTS
Network configuration view
INTERBUS support
Only for AXC F 2152 or AXC F 3152 controllers with AXC F XT IB extension.
LTS
2020.0
LTS
2021.0
LTS
2022.0
LTS
LTS
IO‑Link® support
LTS
2020.0
LTS
2021.0
LTS
2022.0
LTS
LTS
IODD file import
IO‑Link® devices can be operated in an Axioline local bus
IO‑Link® devices can be operated in a PROFINET network
Startup parameters settings
OPC UA® support
LTS
2020.0
LTS
2021.0
LTS
2022.0
LTS
LTS
OPC UA® Security certification management
OPC UA® Data Access configuration view
Extended security settings
OPC UA® PubSub configuration
OPC UA® Reverse Connect configuration
OPC UA® Client configuration
Modbus support
LTS
2020.0
LTS
2021.0
LTS
2022.0
LTS
2023.0
LTS
2024.0 LTS 2024.6
Modbus TCP client
Debug support
LTS
2020.0
LTS
2021.0
LTS
2022.0
LTS
LTS
Logic analyzer     ✔[1]
Logic analyzer – triggered recordings
Logic analyzer – save/load charts
Logic analyzer – up to 16 data points
Logic analyzer – difference measurement between data points
Watchwindow
Watchwindow – support members of UDT
Breakpoints
Execution values (look at every online value in your code – watch the tutorial video
Debug in functions and methods
Online/offline comparison of graphical code worksheets
Comparison of two offline projects
Simulation of AXC F x152
Save data set via Watch Window
  1. Only supports IEC 61131‑3 variables
Model Viewer for Simulink® – Add-in
LTS
2020.0
LTS
2021.0
LTS
2022.0
LTS
LTS
View Simulink® models
Drill down into submodels
Online values for GDS IN ports and OUT ports
Multi-rate models
View Stateflow models
View Truth Table blocks
Cyber Security
LTS
2020.0
LTS
2021.0
LTS
2022.0
LTS
LTS
User authentication – PLC access
User authentication – Change Password
View security certificates of PLC
Login template for web visualization
Remembering user credentials
Remembering multiple user credentials
Hash protection for binaries and local project files
