Real-time DataLogger - Tutorial videos
Available from 2019.6 – some features came in with later firmware releases
cookie
Getting used to DataLogger functions
Frank Walde tells all you need to know for starters about the DataLogger.
As a newbie, please don't skip this introduction so we can get deeper into it in the following two videos without losing you.
Configuring for "Record on time"
In this video, we are setting up a program that logs data from a set of ports into an SQLite database, so we can access those logs from our host computer. Prerequisites here:
DataLogger with OPC UA Historical Data Access
Now it's getting historical! Recruiting the embedded OPC UA® server of the PLCnext Technology Runtime, we will set up our data ports to historicize all values.
We will be using the UaExpert client from Unified Automation in this session, so make sure you have that installed already.
Configuring for "Record on change"
In this video, we are configuring a DataLogger session with a small program to only record changes of the variable values. This is done by means of a .config file which we're editing to our needs.
Prerequisites: Download the DataLogger Service configuration file from the PLCnext repository on GitHub
DataLogger configuration with PLCnext Engineer
Starting with firmware 2020.6 and PLCnext Engineer 2020.6, you can now set up and configure a DataLogger session by means of the PLCnext Engineer interface. Frank shows the procedure for a typical use case involving variables to be read out via OPC UA®.
After that, we will recruit the embedded OPC UA® server of the PLCnext Technology Runtime, set up our data ports to historicize all values.
