Features
Below is an overview with the features in the Device and Update Management versions and the matching PLCnext device firmware versions.
You can use the following DaUM features if the devices to be updated have at least the specified firmware version.
DaUM feature | PLCnext device firmware version[1] | ||||
2023.0 LTS | 2023.3 | 2023.6 | 2023.9 | 2024.0 LTS | |
Firmware update | ✓ All PLCnext devices[2] |
✓ All PLCnext devices [2] |
PLCnext Engineer project update/rollout | ✓ Only AXC F 3152 [2] |
Use of OPC UA GDS | ✓ All PLCnext devices |
- If available for your device. Check whether the firmware version is available for the corresponding device.
- Not for safety applications
Here you can see which DaUM features are available to you with which DaUM versions.
Device and Update Management feature | Device and Update Management version | ||||
Windows® service | 2023.3 | 2023.9 | 2024.0 | 2024.3 | 2024.6 |
PLCnext App | 23.3.0.11767 | 23.9.0.13067 | 24.0.0.14038 | 24.3.0.15373 | 24.6.0.15914 |
Firmware update | ✓ | ✓ | ✓ | ✓ | ✓ |
PLCnext Engineer project update/rollout | ✓ | ✓ | ✓ | ✓ | ✓ |
Use of OPC UA GDS | ✓ | ✓ | ✓ | ✓ | ✓ |
Available as PLCnext App | ✓ | ✓ | ✓ | ✓ | ✓ |
Available as Windows® service | ✓ | ✓ | ✓ | ✓ | ✓ |
REST API | ✓ | ✓ | ✓ | ✓ | ✓ |
Handling of CRLs | ✓ | ✓ | ✓ | ✓ | |
Notification bell | ✓ | ✓ | ✓ | ||
German language support | ✓ | ✓ | ✓ | ||
Parallel execution of updates | ✓ | ✓ | ✓ | ||
Backup and restore 1.0 | ✓ | ||||
Backup and restore 1.1 | ✓ |
• Published/reviewed: 2024-08-08 ☀ Revision 071 •
