Product range
The information in this Info Center is about the PLCnext Runtime System, which is the firmware on PLCnext Control devices. In addition, use cases with related hardware and software are described if useful in the course of a documented feature.
Each PLCnext Control comes with its own hardware documentation, which can be a data sheet containing the commissioning of the controller, or a user manual. For more details, see Hardware documentation.
The engineering tool for PLCnext Control devices, PLCnext Engineer, comes with its own documentation in the form of an embedded help.
Covered PLCnext Control firmware
This platform adds to the product information of these devices:
Product | Product Type | Firmware version | Item no. |
AXC F 1152 | PLCnext Control | 2020.0 LTS or newer | 1151412 |
AXC F 2152 | PLCnext Control | 2019.0 LTS or newer | 2404267 |
AXC F 3152 | PLCnext Control | 2020.3 or newer | 1069208 |
RFC 4072S | PLCnext Control for safety-related operation | 2019.0 LTS or newer | 1051328 |
RFC 4072R | PLCnext Control for redundancy operation | 2022.0 LTS or newer | 1136419 |
AXC F 2152 STARTERKIT (deprecated) | Preinstalled station including an AXC F 2152 and I/O modules | 2019.0 LTS or newer | 1046568 |
PLCnext Technology STARTERKIT | Preinstalled station including an AXC F 2152 and Axioline Smart Elements | 2020.0 LTS or newer | 1188165 |
Note: For commissioning or disposing the hardware, see the respective user manual or data sheet.
Related products
This platform adds to the product information for the following parts of the PLCnext Technology ecosystem:
Product | Product Type | Compatible to devices' firmware version |
Item no. |
PLCnext Engineer | Engineering Software | 2019.0 LTS or newer | 1046008 |
SD FLASH 2GB PLCNEXT MEMORY | Program and configuration memory extension | 2019.0 LTS or newer | 1043501 |
SD FLASH 8GB PLCNEXT MEMORY | Program and configuration memory extension | 2019.0 LTS or newer | 1061701 |
SD FLASH 8GB PLCNEXT MEMORY LIC | Program and configuration memory extension and license storage | 2022.6 or newer | 1151112 |
SD FLASH 32GB PLCNEXT MEMORY LIC | Program and configuration memory extension and license storage | 2022.6 or newer | 1151111 |
SD FLASH 8GB PLCNEXT MEMORY LIC CFG or SD FLASH 32GB PLCNEXT MEMORY LIC CFG |
Program and configuration memory extension and license storage with pre-activated licenses and other files | 2022.6 or newer | 1308064 |
AXC F IL ADAPT | Right-alignable Inline adapter terminal (INTERBUS master) | 2019.0 LTS or newer | 1020304 |
AXC F XT ETH 1TX | Left-alignable Ethernet interface | 2019.0 LTS or newer | 2403115 |
AXC F XT IB | Left-alignable INTERBUS master | 2019.0 LTS or newer | 2403018 |
AXC F XT PB | Left-alignable PROFIBUS master | 2022.0 LTS or newer | 1091657 |
AXC F XT SPLC 1000 | Left-alignable safety-related controller | 2021.9 or newer | 1159811 |
AXC F XT SPLC 3000 | Left-alignable safety-related controller | 2023.0 LTS or newer | 1160157 |
AXC F XT ML 1000 | Left-alignable machine learning module | 2022.0 LTS or newer | 1259849 |
AXC F XT KIT | Left-alignable module with a mini PCIe slot | 2023.0 LTS or newer | 1383116 |
AXC F XT EXP | Left-alignable expansion for up to three AXC F XT modules | 2021.0 LTS or newer | 1139999 |
BPC 9102S | Remote field controller with integrated PROFIsafe® device | 2021.6 or newer | 1246285 |
EPC 1502 | Small form factor Industrial Edge Computer | 2021.0 LTS or newer | 1185416 |
EPC 1522 | Small form factor Industrial Edge Computer | 2021.0 LTS or newer | 1185423 |
- For installing, licensing and using PLCnext Engineer, see the Getting started... topic series.
- For commissioning or disposing the hardware, see the respective user manual or data sheet.
