Configuration - PLCnext Store
Available from firmware 2021.0 LTS
Accessibility
  • Admin
PLCnext Store page
The PLCnext Store page provides status information on the connection between the controller and the PLCnext Store.
You can also specify if you want to operate the controller with or without PLCnext Store connection.
Up to firmware version 2023.3Up to firmware version 2023.3
Enabling the PLCnext Store connection
Security icon
For security reasons, we recommend disabling the PLCnext Store Connector service when the controller is in productive operation. See WBM page System Services
If you want to operate the controller with PLCnext Store connection, you have to enable the PLCnext Store service of the controller. When the PLCnext Store service of the controller is enabled, the controller tries to establish a connection to the PLCnext Store.
  • Enable the Enable PLCnext Store Service checkbox.
  • Click on the Apply button.
The PLCnext Store connection for the controller is enabled. Now you can specify which service you want to use.
Disabling the PLCnext Store connection
If you want to operate the controller without PLCnext Store connection, you have to disable the PLCnext Store service of the controller. In this case, it is not technically possible to establish a connection between the controller and PLCnext Store .
  • Disable the Enable PLCnext Store Service checkbox.
The PLCnext Store connection of the controller is disabled.
