Security Profile
Available from 2022.0 LTS with PLCnext Control AXC F x152 series, and from 2023.0 LTS for RFC 4072S
Accessibility
  • Admin
Note: In order to work with Security profiles with firmware version 2022.0 LTS, you need an active license for the Security feature (see Security profiles
In this WBM page, the Status box shows the current state of activation 1 of a Security Profile. It is also always visible in the header of the WBM  2 no matter which WBM page you're looking at.
If a Security Profile is activated the outcome of the Integrity Check will also be displayed in the head section of each WBM page  2
Activating a Security Profile
  • Check the checkbox in the Configuration section  3.
  • Apply the change to the system by pressing the Apply and reboot button.
The system reboots and is reset to factory defaults type 1 but with a retained IP configuration. By activating the Security Profile, the user Admin is no longer available. Instead, the user SecurityAdmin is created, for which the password printed on the housing of the controller initially applies. Further information can be found in Handling the Security Profile
Note: When a user-defined Security Profile is activated the Netload Limiter is configured with default values by the Security Profile Manager (SPM). All currently available network interfaces of the controller are set to a default value but no limitations are enabled by default.
Deactivating a Security Profile
  • Remove the mark in the checkbox in the Configuration box  3 .
