Configuring Netload Limiter
You configure the Netload Limiter on the Network page (Configuration → Network) in the WBM.
- Log in to the WBM.
- Open the Netload Limiter tab.
- The Time since last reset statistics counter in the upper-right corner of this WBM page shows the time that has elapsed since the last reset of the statistics.
- Statistics are always collected, even if no limiter is enabled.
- Statistics are not reset by applying a configuration change.
- The Time since last reset statistics time counter. It does not reset the controller. However, when resetting the controller, the enabled counters in this WBM page are restarting, too. button resets the enabled packet and byte counters in this WBM page as well as the
When the Packet Limiter or Byte Limiter is enabled but currently not limiting, the status is highlighted green:
When a limiter is enabled and currently limiting, the status shows a red marker for the limiter in question:
You can disable one limiter while leaving the other limiter enabled:
If you're using the AXC F 2152 with the left-aligned AXC F XT ETH 1TX Ethernet module (mandatory in the security context for network segmentation), it may look like this:
• Published/reviewed: 2024-12-09 • Revision 015 •
