Preparing a Library
- Create a Library in PLCnext Engineer.
- Note: If you want to publish your Library with a chargeable license, insert the function block LICENSE_STATUS from the "PLCnext Controller" library into your PLCnext Engineer program.
- Log in to your PLCnext Store account and create a new Library.
- To create a new Library, go to the "Software Products" tab on your profile and click the button.
- In the submenu that opens, select "Library".
A new page opens. On this page you have to describe your Library.
- Fill in the mandatory fields:
- "Library Name*"
- "Version*"
- "Description*"
- "Support email address*"
Note: The name of the library must be unique within the PLCnext Store.
- Add an icon.
- If you want to publish your Library with a chargeable license, write down the Firm Code / Product Code, add the code to the function block LICENSE_STATUS and activate it.
- Save your Library as a draft.
As long as the Library is saved as a draft, the Library is not publicly visible and is editable for you at any time.
→ Next step: Checking a Library.
Or go back to Overview.
• Published/reviewed: 2025-02-04 • Revision 18 •
