Tutorial videos
Note: Tutorial videos are embedded from the Phoenix Contact Technical Support YouTube channel. With playing an embedded YouTube video in this platform, you accept the YouTube Terms & Conditions.
Even showing the video previews on this page depends on your personal settings in the Cookie consent dialog. To watch YouTube videos, you have to allow cookies for marketing purposes which will remain on your device. The data gained through these cookies will be used by YouTube to provide video suggestions and advertisements based on your browsing habits, and may be made available to other parties.
In this segment, the tutorial videos are about:
- PLCnext Technology and the firmware capabilities on PLCnext devices
- Using interfaces and communication standards in context of PLCnext Technology
There are more tutorial videos in this Info Center:
PLCnext Technology
PLCnext Runtime System architecture in a nutshell
06m:02s | HDTV 720p | English | English |
ESM and GDS explained
05m:00s | HDTV 720p | English | English |
Using PROFINET devices
Configuring PROFINET devices from PLCnext Engineer (offline)
02m:19s | HDTV 720p | none | none |
Configuring PROFINET devices from the network (online)
00m:40s | HDTV 720p | none | none |
Configuring PROFINET devices and syncing settings
01m:25s | HDTV 720p | none | none |
Adding PROFINET I/O modules
00m:31s | HDTV 720p | none | none |
Using other protocols, interfaces, frameworks, platforms
Set up an OPC UA® Server on PLCnext Technology
04m:38s | HDTV 720p | English | English |
Transfer a file to a PLCnext Control using the OPC UA® Server
04m:10s | HDTV 720p | English | English |
Connect an AXC F 2152 to a Rockwell controller via EtherNet/IP™
07m:20s | HDTV 720p | English | English |
Using AXC F x152 with extensions and adapters
How to set up AXC F XT ETH 1TX
10m:15s | HDTV 720p | English | none |
Use Inline devices by means of the AXC F IL ADAPT
06m:58s | HDTV 720p | English | English |
