OPC UA Server
On request, an OPC UA® server provides an OPC UA® client with process data and variable values from a running application.
The PLCnext Control devices contain an embedded OPC UA® server (eUA). In addition to the runtime, it is integrated in the controller. It enables access to components, programs, function blocks, structures and variables of PLCnext Technology.
Client-Server communication
Services
The PLCnext Technology eUA Server provides IEC 62541-4 compliant services to client applications:
Information models
The PLCnext Technology eUA server provides IEC 62541-5 compliant information models:
Tutorial - OPC UA setup for PLCnext Control
This tutorial video explains how to configure a secure OPC UA server and client communication on PLCnext Control. It features the following topics:
  • Configure the OPC UA server in a PLCnext Engineer project
  • Check the OPC UA server configuration with the UaExpert reference client
  • Create the OPC UA client in a PLCnext Engineer project
  • Map the variables
  • Activate the OPC UA client feature
  • Where to get a permanent license
  • Set up the certificate authentication on both devices
  • Check for proper notifcations
  • Test the communication with a variables roundtrip
cookie
