System variables - INTERBUS master
Available for AXC F x152
On INTERBUS master devices, three diagnostic registers map the diagnostic display to the control
system:
They inform the control system about the current state of the INTERBUS system. In the application program, operating states, errors, and other information appear as inputs.
Diagnostic status registers
Information on the operating state of the INTERBUS master is stored in the diagnostic status register. A specific INTERBUS master state is assigned to each bit in the diagnostic status register.
The following system variables can be used to read the diagnostic status register information.
Variables in the diagnostic status registers
System variable Type Description
IB_DIAG_STATUS_REG_HI BYTE Master diagnostic status register, high byte
IB_DIAG_STATUS_REG_LOW BYTE Master diagnostic status register, low byte
IB_DIAG_STATUS_REG_SYSFAIL BOOL “System failure” error message
IB_DIAG_STATUS_REG_WARN BOOL Defined warning time exceeded
IB_DIAG_STATUS_REG_QUAL BOOL Defined error density exceeded
IB_DIAG_STATUS_REG_USER BOOL User error/parameterization error
IB_DIAG_STATUS_REG_PF BOOL Peripheral fault
IB_DIAG_STATUS_REG_BUS BOOL Bus error
IB_DIAG_STATUS_REG_CTRL BOOL INTERBUS master/hardware fault
IB_DIAG_STATUS_REG_DTC BOOL Diagnostic routine is active
IB_DIAG_STATUS_REG_RUN BOOL Data transmission is active
IB_DIAG_STATUS_REG_ACT BOOL Selected configuration is ready for operation
IB_DIAG_STATUS_REG_RDY BOOL The INTERBUS master is ready for operation
Diagnostic parameter registers
The diagnostic parameter register provides additional information on an error indicated in the diagnostic status register and is rewritten whenever a malfunction occurs. If no malfunction has been detected, the diagnostic parameter register contains the value 0
Exception: If an INTERBUS local bus error cannot be located then the value 128 is indicated in the diagnostic parameter register (i.e., bit 7 is set).
The location in the local bus structure and an error code is stored in the diagnostic parameter register for each error:
Error location, e.g. device number 3.1
Error code, e.g. "address overlap" = code 0A50hex
For each error code, there's a plain text description and hints to remedy the error, e.g. for the above "address overlap" error:
Error code Type Description and remedy
0A50hex BOOL Error when assigning a process data item. Input or output address assigned more than once.
Remedy:
  • Always assign just 1 process data item to each input/output address.
Add_Error_Info: PDRL index of the incorrect PDRL entry
Find all error codes and their descriptions in the INTERBUS Diagnostics Guide user manual (Prod.-Id. 2747293, IBS SYS DIAG DSC UM E, and other languages - see Diagnostics - Local bus).
Variables in the diagnostic parameter registers
IB_DIAG_PARAM_REG_HI BYTE Master diagnostic parameter register, high byte
IB_DIAG_PARAM_REG_LOW BYTE Master diagnostic parameter register, low byte
IB_DIAG_PARAM_2_REG_HI BYTE Extended master diagnostic parameter register, high byte
IB_DIAG_PARAM_2_REG_LOW BYTE Extended master diagnostic parameter register, low byte
Extended diagnostic parameter registers
The extended diagnostic parameter register is only updated once the "Confirm_Diagnostics" service (0760hex) has been sent. By default, it is set in the MPM at address 37E6hex and can also be moved to the I/O area using the Set_Value service (Variable_ID 010Chex).
