System variables
System time
Available for AXC F x152RFC 4072S, and RFC 4072R
Note: For RFC 4072R, see additional variables in System variables - Redundancy
The RTC system variable is a system variable organized as a data structure. The RTC system variable can be used to retrieve information on the system time of the device's internal real-time clock (in short, RTC). This RTC system variable delivers date and time as local time (not as UTC±0).
RTC system variables
System variable Type Description
RTC RTC_TYPE Data structure
└ HOURS USINT System time (hours)
└ MINUTES USINT System time (minutes)
└ SECONDS USINT System time (seconds)
└ DAY USINT  System time (day)
└ MONTH USINT System time (month)
└ YEAR UINT System time (year)
Note: From PLCnext Engineer version 2023.6 and firmware version 2023.6 the function GET_MICROSECONDS is available to return a timestamp in microseconds since system start.
PLC_CRC_PRJ
Available for RFC 4072SRFC 4072RSPLC 1000
The PLC_CRC_PRJ system variable provides the CRC of the non-safety-related project.
PLC_CRC_PRJ ULINT The CRC of the non-safety-related project
IP socket function blocks
Available for  AXC F x152RFC 4072SRFC 4072R
You can use the TCP_SOCKET and UDP_SOCKET function blocks to open and close the IP sockets that are used for IP communication via Transmission Control Protocol (TCP) or via User Datagram Protocol (UDP).
You can use the TLS_SOCKET function block to open and close IP sockets that are used for secure IP communication via Transport Layer Security (TLS).
You can retrieve the number of opened IP sockets using the following system variables:
IP socket system variables
IP_ACTIVE_SOCKETS UINT Number of IP sockets opened using the TCP_SOCKET and/or UDP_SOCKET function blocks
TLS_ACTIVE_SOCKETS UINT Number of IP sockets opened using the TLS_SOCKET function block
Device state
For RFC 4072R, see additional System variables - Redundancy.
The DEVICE_STATE system variable is a system variable organized as a data structure. The DEVICE_STATE system variable can be used to retrieve various information on the device status of the controller.
Device status system variables
DEVICE_STATE DEVICE_STATE_X152_TYPE Data structure
└ BOARD_TEMPERATURE SINT Temperature inside the housing (in °C)
AXC F 3152RFC 4072S
└ FAN_FAIL
AXC F 1152AXC F 2152
└ reserved1
BOOL AXC F 3152RFC 4072S: The fan is defective.
Device defect due to overheating
Immediately replace the fan when the defect occurs.
Note concerning AXC F 3152: This feature is only available up to hardware revision 03.
AXC F 1152AXC F 2152: Reserved
RFC 4072S
└ RAMDISK_USAGE
AXC F x152
└ reserved2
USINT RFC 4072S: Memory used on the RAM disk
AXC F x152: Reserved
└ CPU_LOAD_ALL_CORES USINT  Average current utilization of all processor cores (in %)
└ CPU_LOAD_PER_CORE CPU_LOAD_PER_CORE_ARRAY Information on the utilization per processor core
     └ [1] USINT Current utilization of processor core 1 (in %)
     └ [2] USINT Current utilization of processor core 2 (in %)
Fan state
Available for AXC F 3152RFC 4072SRFC 4072R
The FAN_STATE system variable is a system variable organized as a data structure. The FAN_STATE system variable can be used to retrieve maintenance or failure information on the optional fan module.
FAN_STATE FAN_INFO Data structure of the fan system variables
└ FAN_MAINTENANCE BOOL Fan maintenance is required
└ FAN_DEFECT BOOL Fan is defective
User partition
The USER_PARTITION system variable is organized as data structure. The USER_PARTITION system variable can be used to retrieve various information and memory statistics about the user partition (Overlay file system). The partition can be located on an SD card or on the internal memory. This memory is organized in blocks. A block has a constant, fixed size, and a file always occupies one or more blocks.
A certain number of blocks is reserved in the Linux system for the root user. Those reserved blocks are only available for the root user and ensure that the root user is able to act even if the memory is occupied (e.g. for log output).
User partition system variables
USER_PARTITION PARTITION_INFO Data structure
└ MEM_TOTAL ULINT Total memory of the partition in bytes
(including reserved blocks)
└ MEM_FREE ULINT Free, available memory in bytes
(without reserved blocks)
└ MEM_USED ULINT Occupied memory in bytes
└ MEM_USAGE USINT  Used memory in %
Utilization monitoring
The utilization of the user partition is monitored by the firmware. The utilzation is shown in the cockpit pages of PLCnext Engineer and WBM.
Furthermore the utilization is shown in IEC 61131‑3 system variables:
  • In case the utilization of the user partition exceeds 90 % an Arp.Device.Interface.UserPartitionUsage.Critical notification (severity: Warning) is emitted.
  • At the same time, the Arp.Device.Interface.DeviceInterface emits a message “Filesystem usage critical: 90 %” (severity: WARN) to the output.log
  • In case the utilization is decreased to 85 % or less another notification Arp.Device.Interface.UserPartitionUsage.Changed (severity: Info) is emitted.
UPS diagnostics
Available from firmware 2022.6  for all PLCnext Control devices with an integrated UPS
Some PLCnext Control devices have an integrated UPS (Uninterruptible Power Supply). In the event of a power supply failure, the device is shut down with the aid of this UPS, whereby the values of the retain variables in particular are saved. The information about the state of charge as well as the functionality of the UPS is particularly important and is therefore provided via the following system variables from firmware release 2022.6:
UPS_DIAGNOSTICS Data structure
└ CHARGE_LEVEL INT UPS charge status in %
└ HWARN BOOL Health Low - warning bit of the status register
The notification UPS health warning is emitted (refer to WBM - Notifications page).
└ HFAIL BOOL Health Failure - warning bit of the status register
The notification UPS health failure is emitted (refer to WBM - Notifications page).
Important: If the system variable UPS_DIAGNOSTICS.HFAIL is TRUE then the controller must be sent to Phoenix Contact for repair. This applies to the controllers AXC F 3152RFC 4072S and BPC 9102S. Please contact Phoenix Contact or your local subsidiary for further details.
The function block UPS_DIAGNOSTICS can also be used to read out diagnostic or status information from the UPS. For more information on the function block refer to the PLCnext Engineer help.
The WBM page Integrated UPS also displays the values and messages of the UPS. You can find further information in Diagnostics - Integrated UPS.
